It is currently Sat Jul 19, 2025 1:04 pm
PostPosted: Mon Nov 20, 2006 2:54 pm
I need to deepen a truss rod channel on a finished (carved) neck. After I did my final flattening my truss rod is about 1/64 too tall.
Any thoughts about how I can deepen the channel just a smidge?
Worst case I can make a sanding stick to do it, but I figure that SOMEONE has bumpped into this problem and solved in in a very easy way.
PostPosted: Mon Nov 20, 2006 3:02 pm
Find a chisel about the width of the channel and use it as a scraper. If I was just getting dust, I would make a little scraper and put a bur on it.
PostPosted: Mon Nov 20, 2006 3:09 pm
can you route it? clamp a flat board to one side and use as a guide...
PostPosted: Mon Nov 20, 2006 3:28 pm
I had that problem on my current build, Brock. I did what Ken said. Used a sharp 1/4" chisel as a scraper, and it worked well.
PostPosted: Mon Nov 20, 2006 3:42 pm
I've had to do this a couple of times, and I just used a very sharp 1/4" chisel to lower the bottom. I just pared away at the bottom until I reached the depth that I needed.
AlA Peebels39041.9881365741
PostPosted: Mon Nov 20, 2006 3:50 pm
Only thing I see when using a chisel is there's a possibility of not getting an even depth all the way down the chanel. No biggie but I prefer an even channel to get rod contact all the way through the chanel.
PostPosted: Mon Nov 20, 2006 4:13 pm
Last Name: Garrish
Router plane, it's the perfect tool for that sort of thing. I don't have one, but it was a good friend of mine when I was with Al Carruth.
Bob Garrish
PostPosted: Mon Nov 20, 2006 4:29 pm
The problem with routing is that if the neck is finished, you'd need to
move the neck on top of a router table. It wouldn't be hard if you had a
sled made for the neck with the same taper. It wouldn't be hard, but why
make a special sled when you can sand it in a few minutes?
PostPosted: Mon Nov 20, 2006 4:50 pm
If you only need to lower the channel a 64th why not put a file on edge in the channel and file away? You will remove the 64th in no time and it will be flat as well.
PostPosted: Mon Nov 20, 2006 7:04 pm
I sort of hate to remind you of this Brock, but didn't something similar as this happen about 8 months ago.
Here's your first post on the topicRod True39042.1289814815
PostPosted: Mon Nov 20, 2006 10:44 pm
Last Name: Watkins
City: Lake Zurich
State: IL
The router plane is definitely the way to go, but no need to buy one if you have a cheapo honing guide lying around...
John Watkins
CNC Guitar Parts
PostPosted: Mon Nov 20, 2006 11:15 pm
I like Robbie's idea a lot, not too agressive and effective, ask me how i know this!
PostPosted: Mon Nov 20, 2006 11:39 pm
[QUOTE=Rod True] I sort of hate to remind you of this Brock, but didn't something similar as this happen about 8 months ago.
Here's your first post on the topic[/QUOTE]
Last time it was flat, this time it is carved.
I have a solution when the neck is still flat... but it won't work on a carved neck.
PostPosted: Tue Nov 21, 2006 1:06 am
[QUOTE=John Watkins] The router plane is definitely the way to go, but no need to buy one if you have a cheapo honing guide lying around...[/QUOTE]
Very clever John, I will remember that one, veeeerrrry clever
Brock, if you make a caul to hold the back of the neck I bet it will come in handy for lots of jobs after this one down the track. If you do not want to go to the trouble, maybe you could pack out your vice with some high density foam rubber and clamp the neck from the side.
Another alternative is to proceed ahead and get the tuner holes drilled. Make a flat block caul with some dowels protruding in the same pattern as those in the peghead, you should only need 2. Clamp the caul in a vice or onto a bench and then clamp the heel to support it laterally and you should be set to go with Johns trick,(veeeery clever John) or a 271 router plane, or a scraper as suggested above.
Hope this helps
PostPosted: Tue Nov 21, 2006 1:16 am
Thanks... These are good ideas.
Ah, ok sorry Brock.
PostPosted: Tue Nov 21, 2006 1:21 am
I just had the same issue and resolved it by free hand routing with a smaller diameter bit., staying away from the channel sides. I cleaned it up with a chisel...the whole process took maybe 10 minutes. Of course you have to be careful freehanding the router but I did not have any difficulty with it and will do it again if the need arises.
good luck,
Tom Armstrong
PostPosted: Tue Nov 21, 2006 4:25 am
I'll second the router plane recommendation. You usually can find them
pretty cheap on the 'bay', and once you have one you'll find more uses for it
than you thought you might. Wonderful tools.
PostPosted: Thu Nov 23, 2006 3:21 am
Brock,
I made a wooden base for my lam trimmer and then glued a two inch long strip of wood that just fit in the slot and lined up with the router bit. The wood strip guides the router bit and recutting the channel depth is a very precise and easy.
